Old 11-07-2011   #1
ammrpm
ammrpm's Avatar
Default FS: Fuel Injectors and Rear Hub/Bearing assemblies
I have the following items for sale...
All items are located in Houston, Tx.
1. Full set of 16 used fuel injectors, 8 primary and 8 secondary, from a 93 ZR-1. These were working when they were removed from the car. They would most likely need to be cleaned to work their best.
Asking $225 + shipping +paypal fees
2. Bearings have been SOLD!
Aaron
ammrpm is offline   Reply With Quote
Old 11-08-2011   #2
Default Re: FS: Fuel Injectors and Rear Hub/Bearing assemblies
Aaron,
Interested in the bearings. I'm assuming they accommodate ABS?
Old 11-08-2011   #3
ammrpm
ammrpm's Avatar
XfireZ51 - I assume they will work just fine with ABS. They were bought for a 95 corvette that had ABS as well. I did not put these on that car though, so I am not 100% sure.
Old 11-08-2011   #4
Basically the bearings have a "strobe wheel" as part of them so the ABS sensor, attached to the hub, can read it. I'll PM u on them.
Old 11-08-2011   #5
Jagdpanzer
Jagdpanzer's Avatar
ABS sensor is seperate on the rear hubs.
It installs on the suspension knuckle and sinses speed from the gear wheel pressed on the axle spindle.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-08-2011   #6
ammrpm
ammrpm's Avatar
Phil - thanks for the pictures and explanation.
Old 11-08-2011   #7
Yes, thx Phil.
Old 11-09-2011   #8
ammrpm
ammrpm's Avatar
