![]() Join Date: Mar 2007
When putting the heads together noticed this:
![]() small nick in valve, I assume from when the engine ingested a small screw, any thoughts if this is a concern....valve is not bent. I assume it will not be an issue
#2 | |
![]() Join Date: Nov 2007
So, if you hafta use that valve, then smoothing the divot so as to remove any edges would be in kind with what is done in some other situations where cracking is at issue. I think I would get another valve first, if at all possible. JMO FWIW, P. |
![]() Join Date: Feb 2011
If that nick doesn't pass thru the seal, that's probably usable, and I probably would on some 200 hp engine, but I too would try to find a replacement given the attention to detail you have into the project so far.
#4 | |
![]() Join Date: Jun 2004
Lee do you need a valve or 2 ?? I got a bag of them. Let me know.
Thanks.....will be replacing it...got a bag of them too with Paul D estate auction.
#8 | |
Smart decision Lee, no need to take the risk.
