Wow,
I have learned a lot about the LT5. OK, NEW Starter Coil packs Red Plug wires FIC Flow Matched Fuel Injectors Jerry's Gasket Viton Alcohol Resistant O-Rings entire Fuel Rail Water Pump Alternator Goodyear Serpentine Gator Groove Belt AC Clutch Kit NGK V-POWER Spark Plugs Plenum Gaskets Preventive maintenance on air lines, electrical connections, ext. PVC system maintenance Fresh Amsoil 10-40 High Zinc Formula. Which I have been using since the early 70's ![]() Last But Not Least FRESH Anti-Freeze The GREEN Stuff! Thanks Car Quest!! It runs like never before. ![]() Thanks again to all who answered questions, on the net, through the ZR-1 Net Registry on this and all topics. Some of the HOW TO Articles that have been on the Registry for awhile but still contain priceless info for all of us working on our cars. ![]() Last edited by lakemeadzmonster; 02-09-2011 at 12:09 PM. Reason: add a few words |
After having a brief scare on my secondaries not opening and check engine light coming on.
Thanks to the Forums help, I traced the vacuum leak to the double connector outside of Plenum ( front left side below fuel rail) a real hard one to get to and it is the plastic tube going into the rubber. I renewed it and it seals and holds vacuum once again. Fresh High Dollar High Octane at Sam's of Las Vegas Eastern & Serene Store. A shot of AmsOil Octane Booster and I'll be seeing everyone at Cars and Coffee this weekend. ![]() |
![]() Join Date: Dec 2004
![]() ![]() Enjoy your new toy! ![]()
Hows that Rebel gas
