Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 12-08-2010   #1
QB93Z
QB93Z's Avatar
Thumbs up WMD - Sunday, December 12th, in Westminster, MD
Everyone is invited to my garage in Westminster, Maryland on Sunday, the 12th of December for a Westminster Maintenance Day.
We are planning on doing rear suspension and differential work on my 1994 ZR-1. Then, if we have time, replace the differential on David's 1994. (gear ratio change). Plus what ever anyone else needs to work on.
We will start about 9 AM.
Call or post here if you need directions.
Old 12-08-2010   #2
ZR-1nce removed
ZR-1nce removed's Avatar
Default Re: WMD - Sunday, December 12th, in Westminster, MD
I'm in! (I may bring a set of injectors along.)
90 ZR-1 #0951 Bright Red (sold)
06 Z51 MN6 Velocity Yellow (sold)
2023 C-8 Z51 ELB
ZR-1nce removed is offline   Reply With Quote
Old 12-08-2010   #3
Bring'm! We can have yours in the other bay.
Old 12-08-2010   #4
Aurora40
Aurora40's Avatar
It's actually supposed to warm up (a bit) for the weekend, so that'll be good. I'll keep the WMD in mind!
Old 12-09-2010   #5
QB93Z
QB93Z's Avatar
I will be stocking up on propane so the heater will be in full blast mode. Can you say toasty?
As an added bonus, I will try to get a coffee maker operating out in the garage and I will be serving hot spiced cidar from our local orchard.
OH yea, we may also work on some ZR-1's!!
Old 12-10-2010   #6
Aurora40
Aurora40's Avatar
Ok, so I'm curious... Swapping the differential on David's car? He already has 4.10's, what are you swapping them to?
Also, just a suggestion, if you can, park a couple of ZR-1's that have been driven there in the garage. A fully warmed up LT5 is about the best garage heater you can imagine, at least to get the warm-up started. That's generally what I try to do in the winter, work on the car after I've driven the other in the garage. It warms the place up substantially faster than any space heaters do.
Old 12-10-2010   #7
RICKYRJ1
RICKYRJ1's Avatar
I beleive he is going back to stock gearing. You know him, he changes stuff on his car as much as he changes his underwear.
Old 12-10-2010   #8
QB93Z
QB93Z's Avatar
David has a three change limit (equipment not underwear) at my garage. No more than three changes of a particular component in a calendar year. I have heard reports that he has been two-timimng me and visiting other garages.
Old 12-10-2010   #9
Scrrem
Scrrem's Avatar
Jim, I heard rumors of that myself...say it isn't so!!!! Just for that, you need to ensure David's hands see plenty of grease and grime changing that axle
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-10-2010   #10
QB93Z
QB93Z's Avatar
Hey Rich, what sealant did you use to seal the differential to the bat wing?
Thanks, Jim
