Old 02-03-2006   #1
NewZpilot
NewZpilot's Avatar
Default Help, my new Z stumbled on the highway.
Ok Im new to having a zr (6 days) and had an issue, heard you guys are the ones to ask . Cars been great until on the highway in full power I stand in it in 3rd at 50-60 miles and hour and it studders then creapping allong on the highway it does the same thing while the service light comes on??After limping it back to work 2 miles it cleared up and was back to running smooth and after parking it for a few hours when I headed home the service light was gone? NO volt issues, no heat issues, no oil pressure issues, Just not sure what to start with ?
NewZpilot is offline   Reply With Quote
Old 02-03-2006   #2
Jeffvette
Default Re: Help, my new Z stumbled on the highway.
The best diagnostic tool to have is a paper clip.
Unbend the paperclip so it is in a "U" shape. Plug it into the ALDL ports (port in the drivers side footwell) A-B. This will hit the ecm codes which will be stored. trun the key to "run"
Count the pulses.
flash.... flash flash is a code 12 which means it is entering the system. Anything after that is a code(s) which will help troubleshoot.
My best guess is your secondary system is at fault, hence the stumble at WOT.
Old 02-04-2006   #3
I'm going with secondary leak
Old 02-04-2006   #4
RICKYRJ1
RICKYRJ1's Avatar
Sounds like the car is shot!! Call me if you want to get rid of it cheap!
Old 02-04-2006   #5
NewZpilot
NewZpilot's Avatar
Yeah I should prob. hook it. WHos in for a 6pack and some nuddy mags for my z? What ever ill push this car to the corvette show just to look cool before I hook it. My wifes already jealous of her and Ive only had it a week. Its good to know If I needed out I can always count on you.
Old 02-04-2006   #6
Aurora40
Aurora40's Avatar
The paperclip thing Jeff said will take you 30 seconds. You'll know a lot more from those two digits of the troublecode.
What does "hook it" mean?
Old 02-04-2006   #7
RICKYRJ1
RICKYRJ1's Avatar
How did you know I wanted to pay you in porn? Good Luck with the fix. I agree pushing or pulling your Z will still look better than anything else.
Old 02-04-2006   #8
Corvette95
Corvette95's Avatar
NewZpilot, I know this is "off topic" but can you check the front fog light area of your see and tell me if the black area around your fog lights has any white overspray paint on it like mine?
http://temp.corvetteforum.net/c5/cor...ight_front.jpg
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-06-2006   #9
NewZpilot
NewZpilot's Avatar
Ok no paint overspray and found out at GM sat may car pulled a code 31 or a cam sensor. Since the light went out they claim wait till it fails and then fix it????
Old 03-14-2006   #10
BBBAD94ZR1
BBBAD94ZR1's Avatar
My car did the say exact thing, took it to the dealer and had the injectors flushed while the fuel was cut off. Put on a new fuel filter, new plugs gapped .50 and the car runs like a top.=D>
Ray
BBBAD94ZR1 is offline   Reply With Quote
