Old 08-01-2010   #1
Default Differences in knock sensors?
The knock sensor is a piezoelectric crystal with a pickup wire. But, apparently, the associated "plumbing" includes a resistor network that differs among the model years. According to Bob G, a sensor from another MY resulted in considerable timing retarding on one of his engines (the ECM falsely sensing knock, apparently).
Mine works, far as I know, but the plastic ring to which the connector "grabs hold" got brittle with age/heat and part of the ring broke off - now making the connection precarious at best!
So, Q: Has anyone found a reasonable facsimile, if not an OEM, knock sensor that works on a 90? Granted, the connector may have to be changed to accommodate one from a different source/application, but this car is an FBI "warrior" and not a waxer; NCRS is not an issue here.
TIA
P.
Old 08-01-2010   #2
Default Re: Differences in knock sensors?
I didn't know there was a difference in the knock sensors until I went to the ACDelco site: Lo & behold, the 90 is a different PN.
1990
SENSOR,KNOCK
Part Number: 213-94
Product Notes:
[Knock Sensor]
Per Vehicle: 1; Years: 1990-1990
CONNECTOR,SEN-KNOCK
Part Number: PT2295
Product Notes:
[All Makes-Sensor-Knock Connector]; 1-Way male
Per Vehicle: 1; Years: 1990-1995
1991~95
SENSOR ASM-KNOCK
Part Number: 213-266
Product Notes:
[Knock Sensor(VPI 1-877-846-8243)]
Per Vehicle: 1; Years: 1991-1995
Vehicle List
CONNECTOR,SEN-KNOCK
Part Number: PT2295
Product Notes:
