Old 08-12-2014   #1
nelson007
nelson007's Avatar
Default Need help. Hard top foam padding.
Can someone advise me where to,purchase the foam headliner. After removing the one in my car it looks pretty bad.
Thanks,
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
Old 08-12-2014   #2
Z06scentair
Z06scentair's Avatar
Default Re: Need help. Hard top foam padding.
Corvette America sells an entire new liner for $149. Mine looked bad when I pulled it out.
Would have never had a sound sleep if I had put new fabric over that broken up board.
My problem is I ordered as always from Corvette Central only to find out Corvette America is the manufacture. The headliner arrived damaged bent in half in a Corvette America box.
Called and asked for replacement from Corvette Central, let the run around begin!
Never ever ever never ever will I ever do buisness with Corvette Central ever again! Did I say Never? Hell yeah!
Ordered another from Corvette America today. Did a chargeback on Corvette Central Today.
Brad
Old 08-12-2014   #3
KILLSHOTS
The Registry store has some nice embroidered suede headliners for less than the fabric ones at the Corvette stores. Less money, plus you're helping the club.
Old 08-12-2014   #4
Nelson,
This is what I used. Comes with sponge backed cloth and a can of spray adhesive. I'll install for you if you want when we have our next WMD maintenance day. I think Ron Kreigh needs the same service also.
Old 08-13-2014   #5
nelson007
nelson007's Avatar
I bought the headliner from the Net Registry store, p that looks great, what i need is the foam padding it is glued-to.
Thanks,
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
Old 08-13-2014   #6
WVZR-1
I believe I'd visit a local auto upholstery shop and see the offerings. I believe you're looking for KP sheet that is used in most of the later headliners. They should have different offerings I believe in thickness. Catch them in a proper mood and the install might be a bargain. It certainly doesn't hurt to ask. The finish is sometimes worth the professional install. If you didn't have the headliner already they can usually accommodate you with a very nice headliner from remnants that can't do other projects.
I did mine in '03 but I had a relationship with the trimmer.
Old 08-13-2014   #7
nelson007
nelson007's Avatar
Thanks for the advice, I will try that. I bought the liner from the Registry store and that looks great.
Nelson 007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
Old 08-14-2014   #8
Schrade
Mine was borderline when I got it out.
I put a mini-roller to it, with water based Acrylic Latex Black, which checked the dust, and reinforced the pad.
