Old 05-24-2010   #1
jonszr1
jonszr1's Avatar
Default cam cover ????
the spark plug o rings on the passenger side cam covers have started leaking. is there something that might have caused this, a vibration?or something else . i have owned the 92 for 3 years and have never taken them off . thanx to rick for guiding me on its removal. also is there anything to ck while its off ????
Old 05-24-2010   #2
Locobob
Default Re: cam cover ????
Did you check the bolts for tightness? I have run across a few that have some how backed out on their own.
Robert
Old 05-25-2010   #3
jonszr1
jonszr1's Avatar
no i havenbt . i had to get an inch pound tq wrench ,which i did today. i have new o rings and got some 518 locktight so i figured i would pull it off and put new o rings on the spark plug tubes . is there anything i should take a look at while i have it off ???
Old 05-25-2010   #4
Brad, two things you may want to look at while you're under there.
The chain guide strips in the cam cover, and there is a breather filter where the aluminum tube comes from that maybe falling apart.
Old 05-26-2010   #5
jonszr1
jonszr1's Avatar
tom thankyou for the heads up on the timing chain wear strips. . will be kina fun ckin out what it looks like in person under there as i have never seen that first hand
Old 05-26-2010   #6
Brad. I never seen any of that stuff first hand either!
I would be interested in hearing your thoughts after you get your eyes on this stuff.
