Old 03-20-2009   #1
rhipsher
rhipsher's Avatar
Default Wheel bearings.
I need to find wheel bearings for a 90 beast? Thanx in advance.
Old 03-20-2009   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Wheel bearings.
http://www.corvettewheelbearings.com/
http://www.corvetterecycling.com/category_s/23.htm
Old 03-21-2009   #3
Aurora40
Aurora40's Avatar
According to Timken's application guide, for a '90 the front bearing is #513019 and the rear is #513020. RockAuto has the fronts for $150 each, and the rears for $140 each.
I would think that's a good price, but don't really know. I've always heard they are good bearings, that's what I've bought for other cars. Are they a good choice on these cars?
Old 03-21-2009   #4
Several years ago, there was a lengthy discussion about different mfg wheel bearings. I remember the thread because I was planning to replace all 4 of mine. The final concensus was that Delco was the best, not for price, but for reliability.
Now, there is a HD rear offered with a better bearing than OEM Delco. The rears are more prone to failure than the front. Here's the description. Sounds like a Timken style bearing.
Manufactured by a leading American Hub Bearing manufacturer designed to produce an advanced rear hub for the 1984 to 1996 Corvettes. The uniqueness of this hub bearing is the use of a tapered roller bearing with a nitrate hardened race. The OE design hub uses ball bearings with a machined race into the hub assembly. The redesigned assembly includes a nitrate hardened race machined into an American forged hub. The combination of a super hard surface with tapered roller bearings, produces an increase in surface area for side load which delivers improved durability and performance.
Features Include:
American Forged Hub and Spindle Flange Assemblies
Re-designed With Tapered Roller Bearings and Races
Tapered Bearings increase Load Surface for Extended Life
Manufacture to ISO 9001 and TS16949 Standards
Old 03-21-2009   #5
DMark
DMark's Avatar
I just had fronts & rear bearings from Corvette Recycling installed. These are NOS GM and they had the best prices that I have found.
Alot of China-Junk bearing out there - Beware!
DMark is offline   Reply With Quote
Old 03-21-2009   #6
gbrtng
gbrtng's Avatar
http://tld-corvette.com/products.asp?dept=859
used to handle ACDelco for the 91-96 too. Looks like cheap not-so-good stuff now.
Old 03-21-2009   #7
rhipsher
rhipsher's Avatar
It would be nice if you could just replace the bearings instead of buying the whole hub. But it doesn't look like thats an option. I'm gonna keep my eyes and ears open for a good deal on all four. So far $100 a piece front and $199 for rear are the best price yet I've seen. I've used Timken bearings for non auto related things and they are good stuff.
Old 03-22-2009   #8
lbszr
lbszr's Avatar
Might be some for front 91-95 and could work on 90 with modification, but not cheap. http://mjmracing.shutterfly.com/
National by federal mogal have held up good for me if there the ones with a national ink stamp on the rotor mount flange.
Old 03-22-2009   #9
32valvZ
32valvZ's Avatar
Those seem like prices for Asian made assys. Save your money & buy American pieces in this area. Safety has no price.
Old 03-22-2009   #10
Jeffvette
Rick, buy GM bearings. Don't waste your time.
