anyone know of who does suspension upgrades for our cars am looking for stuff that will help the caR launch at the drag strip? thanx
People have posted some DIY methods. I think removing the shock actuators and setting the rears to max firm and the fronts to max soft. And something about disconnecting one of the anti-roll bars.
The ZF.DOC does some nice beam plates. I have these installed and they work well. Tell him I sent you! Goldcylon
![]() C4 Beam Plates (Fits all 1984 -1996 Corvette Drivelines) Lifetime Warranted Retail price - $189.00 To Purchase call (602) 319-6575 or email www.billb@zfdoc.com ![]() Last edited by GOLDCYLON; 09-25-2007 at 11:37 PM. |
thanx hor the thought . i allreagy got a set of those bad boys when bill put my clutch in . i ll have to try the sway bar deal . might have to try some different shocks. hAVE HEARD OF SOME THAT HAVE SHIMMED THE bumpers .the rubber thing that stope the car from going to far down. sure wish yjere was a way to get a better 60ft . 2.92 is killing me .maybe go to 16s for more side wall flex . any ifeas ya got please write them down .somethings got to work thanx
#5 | |
You didn't say what tires you were running, or what suspension setting you use.
You also didn't give a clue as to your launch technique. What RPM are you launching at? Dumping the clutch, or feathering out off the line. The more you tell us, the more we can help. Last edited by Greybeard ZR1; 09-29-2007 at 03:29 PM. |
sorry for the incomplete info. also 60 ft should be 2.02 not 292. I am using mt et streets @16lbs have done the best withsusp on easiet shock setting . 1/2 tank of fuel spare tire removed . do the best burnout i can without a line lock. then leave at betwween 2500 -3000 ,with a fast release of the clutch ans squeeze the throttle. short shift 1-2 @6500 2-3 @ 6800 as wellas 3-4 go through the lights @7000=if i carry first to 6800 i spin the tires way too much .. if i couldget rid of the squat i think that would help . also thinking of trying a 16in tire maybe more sidewall would help
If you run too little pressure your tires will cup and youll lose your contact patch.
You can lose on the big end also with too little psi not to mention it can handle a little funny at speed. Try Fastlane or Dick Guldstrand, too. |
![]() ![]() Join Date: Dec 2003
Jeb Burnett on corvetteforum (jburnett) is a great source for IRS upgrades.
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
#10 |
does jeb burnett post here .I do not go on the corvette forum( igot railroaded and then banned ) basicly not very fair people . jmho. mt people say to run between 11-14 lbs but that is just a little to low for old guy
