Old 04-26-2024   #1
JohnQ
Default P/N: Mufflers and Resonator - '92 ZR-1 (WTB)
Can anyone provide the correct part numbers for the OEM mufflers and resonator for a '92 ZR-1? I'm interested in buying both mufflers and the resonator. I'm also curious what these items will cost to acquire. Thanks.
JohnQ is offline   Reply With Quote
Old 04-26-2024   #2
Default Re: P/N: Mufflers and Resonator - '92 ZR-1 (WTB)
John, you probably already know this, but the stock exhaust systems were one piece welded units from the cats back through the mufflers. There are undoubtedly parts number for each for repair and replacement purposes, but I would bet most folks just have complete systems. And the complete stock systems should not be prohibitively expensive. Good luck nevertheless. --Bob
Old 04-26-2024   #3
JohnQ
Thank you Bob. While I'd consider the entire one-piece system, it may be difficult to ship so I'm also open to just the mufflers and resonator even if they've been cut off from rest of the exhaust pipes. But I need to start with identifying part numbers so that I can start searching. I've come across some mufflers advertised as correct for the ZR-1, but I have no way to verify. I have the same issue in identifying the resonator. Thanks again for your info!
