Old 05-16-2021   #1
billschroeder5842
billschroeder5842's Avatar
Default Please help diagnose popping sound prior to "diving in"
Hey All,
Can you help point me in the right direction with a few "check this out" before I start tearing into things? My '91 has about 85k on it and runs smooth with all original (except shocks) suspension components.
I'm getting an intermittent driveline noise and if feels/sounds like it is clutch related. Here are the "symptoms:"
1) Intermittent slight "quick metallic popping" sound. Reminds me of the sound my rear hub shaft makes. (I've taken that thing apart several times to no avail- I now just look forward to hearing it)
2) Seems to be only when I take off from a start, only "pops" once- occasionally and non predictable. Cold or warmed up, makes no difference
3) Feels like when I'm more aggressive (not burn out aggressive) I get the noise. Starting easy and releasing the clutch slowly and there is nothing.
4) Never get the noise in any other gear.
5) No driveline vibration
6) Clutch feels normal and fluids are good
At times I wonder if my dual mass flywheel is having "moments" as the sound "sort of, kind of" reminds me of a "clicker" version.
I appreciate any direction- I know that diagnosing sounds is difficult!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 05-16-2021   #2
32valvesftw
Default Re: Please help diagnose popping sound prior to "diving in"
I had a weird noise like that, it went away when the suspension was greased. My other thought would be a half shaft u-joint that is worn.
Old 05-16-2021   #3
Ccmano
Has the C Beam been out? Re torque the C Beam bolts and see what happens. If that's it get a set of Beam Plates from ZF Doc.
H
Old 05-16-2021   #4
billschroeder5842
Thanks guys. I'll check both the C beam (I never would have thought to check that) and the u joints along with a general inspection. Plus it never hurts to give everything a shot of grease.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 05-16-2021   #5
Also check the rear wheel hub washer. As the Teflon tend to wear the popping continues
Old 05-16-2021   #6
Does Jerry carry those washers?
Old 05-16-2021   #7
Not sure and they are becoming hard to find. They are the same part number the entire C-4 run and not ZR-1 specific. However I have heard that popping noise before and it?s those darn washers . GC
Old 05-16-2021   #8
billschroeder5842
Yeah, I've replaced the washers in the rear and it still pops. I went +10 on the torque and it did not seem to matter.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 05-17-2021   #9
Corvette95
Corvette95's Avatar
watching thread, I would like some of those washers too if anyone has a source and part# (but only after the OP gets theirs first).
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 05-17-2021   #10
I will look into it.
Does anyone have a new or good used one that I can sample from for material analysis & dimensions?
