![]() Join Date: Nov 2010
Going to be swapping out the failing primary pump tomorrow with a buddy using a spare OE pump I have. Which pump is the primary and which is the secondary? I'm sure I can figure it out by the wiring, but I'm guessing you can also tell by the position (one is lower than the other).
![]() Join Date: Sep 2016
The lower one is the primary. The upper one secondary.
Why not replace both while your taking trouble to pull it all out. Pumps are cheap.
H ![]() |
#5 | |
Oh well, changing the pump is actually pretty easy. And you're correct, they are cheap (didn't realize how cheap). So I guess I'll order a new pair of pumps and go ahead and change both. Anybody try the Autobest HP2251 before? Found it on Rockauto and it's supposed to flow at least 15% more than stock: https://www.rockauto.com/en/moreinfo...sn=908&jsn=908 |
![]() Join Date: Aug 2015
Evan, make sure you also check the harness where it connects to the bulkhead. I've had numerous issues with corrosion there which will shut down the pump(s).
Steve Sent from my SM-G950U using ZR-1 Net Registry mobile app |
