Old 02-14-2015   #1
Bolling
Default Z06 Wheels fit?
Will C6 Z06 wheels fit our ZR1's and how bad would the speedo be off? I also posted in the wanted section by accident, sorry.
Bolling is offline   Reply With Quote
Old 02-16-2015   #2
HIZNHRZ
Default Re: Z06 Wheels fit?
These are C6 ZR1 wheels with C6 Z06 diameter, width, and tire sizes. The offset is as close to a C4 ZR-1 wheel as I could find.
The wheels are 18 X 9.5 inch (fronts) with a +57mm offset and rear wheels are 19 X 12 inch with a +59mm offset.
I used a spacer on the rear wheels. The outside edge of the wheels and tires are located and look the same (as the OE wheels and tires) in terms of their location to outboard side the wheel housing. Sourced a 10mm spacer for the rear wheels. The rear tires are also 1" larger (than OE) in diameter. The front and rear suspension was lowered 1/2". The speedometer was corrected +4%.
Old 02-16-2015   #3
Bolling
Looks great, Thanks
Old 02-17-2015   #4
USAFPILOT
USAFPILOT's Avatar
Regular factory ZO6 wheels will fit...the fronts will bulge out past the fenders just a tad.
Old 04-16-2021   #5
wfot
wfot's Avatar
how exactly was the speedo corrected by 4% ?
trans gears or done electronically?
Thanks
wfot is offline   Reply With Quote
