Old 06-29-2020   #1
BigDave
Default FS: 93 Anniversary ZR1 Parts
I have a 93 Anniversary Ruby Red ZR1 that had 6800 miles when damaged which I have parted out. The car has been garaged for the last 15-20 years. I?m selling the remaining parts as a single purchase. Below is a list of some of the parts: I will be listing the remaining parts in new post.
Rear Pumpkin Model 44 with 4:10 gears and Bat-wing SOLD
Drive Shaft SOLD
Both Half Shafts SOLD
Left and Right Rear Suspension Knuckle Assembly with Spindle, Wheel Hub and Anti-lock Brake Tooth Ring with pickup
Left and Right front upper and lower A-arms with spindles
Hood
Headlight assemblies SOLD
Fire Wall
Front Bumper covers (2), Impact Bar, Energy Absorber, etc.
Rear Impact bar and Energy Absorber
Right Rear Fender
Spare Tire and Spare Tire carrier
Left and Right doors, regulator assembly with motors, water deflectors, glass, etc.
Left and Right Ruby Red door panels
Complete carpet set
Seat frames and Seat back frames
Front and Rear Brake Calipers
Vacuum Brake Booster (new) SOLD
Clutch master and slave cylinder
Rear wheelhouse liners (look new) SOLD
Front and rear springs with mounting hardware
Front and rear Sway Bars with mounting hardware
Oil Cooler (new) SOLD
Bell Housing SOLD
Exhaust Manifolds with catalytic converters SOLD
16 Fuel Injectors SOLD
Fuel Rails and crossover tubes SOLD
Secondary linkage, diagrams, shielding and hardware SOLD
Engine and Exhaust Shielding
Coil Tray with 4 Coils SOLD
Wiper motor and linkage
Steering shaft assembly
Hood release cables and release handle
Rear Fender Supports (4 pieces)
Under dash AC plenum assembly
Frame to hood support brackets
Drive line support (2)
Under body X-Brace ? Aftermarket (new)
Power steering pump pulley (new) SOLD
Water pump pulley (new) SOLD
Air pump (new)
Urethane Suspension bushing set ? Total Kit (new) SOLD
Hood emblem
Alternator SOLD
Ruby Red seat belts
Brake and Clutch paddle assemblies SOLD
Hood Hinges
Power Antenna [B]SOLD[/B
Tail light lenses SOLD
Steering pump bracket SOLD
Oil filter bracket SOLD
PCV valves and vacuum lines SOLD
Battery cables
Power steering tank SOLD
Roof panel front hold downs
Air diffusers for dash
ABS/ASR Modulator valve SOLD
Radiator inlet pipe (new) SOLD
Cruse control module
Low tire pressure module
Intake Air Horn Bolts SOLD
Water Pump Bolts SOLD
Fuel Injector Housing bolts SOLD
Exhaust Manifold bolts with spacers SOLD
Throttle Body shield and bolts SOLD
Coil Tray Bolts SOLD
Ignition Control Module Bolts SOLD
Alternator Bracket and bolts SOLD
Flywheel Bolts SOLD
Coolant outlet cover bolts SOLD
Transmission to bellhousing bolts SOLD
Bellhousing to Engine bolts (Includes dust shield bolts) SOLD
Water Pump to A/C bracket and bolts SOLD
Intake Plenum Bolts SOLD
BigDave is offline   Reply With Quote
Old 06-29-2020   #2
Default Re: FS: 93 Anniversary ZR1 Parts
I?d be interested in fog lamps and sun visiors
Old 06-30-2020   #3
BigDave
PM sent
Old 07-28-2020   #4
BigDave
Thanks to Jerry at Jerry's Gaskets for his purchase of many of these parts. He's a good guy to work with.
Old 07-28-2020   #5
32valvZ
32valvZ's Avatar
Im interested in the power antenna if it works with my 90...
Old 07-28-2020   #6
Karl
Karl's Avatar
Interested in the urethane bushing suspension kit. Is this for the entire car? Do you have a picture?
Old 07-28-2020   #7
mpiecyk
Hey Big Dave, You must clear your storage in order to accept any new messages.
Thanks
Mike P.
mpiecyk is offline   Reply With Quote
Old 07-28-2020   #8
BigDave
Done.
Old 07-28-2020   #9
mpiecyk
Big Dave,Where are you located in Illinois.
Old 07-28-2020   #10
BigDave
By the Peoria Airport.
