Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 11-08-2016   #1
QB93Z
QB93Z's Avatar
Default WAZOO WMD - Nov 12, 2016 - Westminster, MD
I will be holding a Westminster Maintenance Day (WMD) on Saturday, 12 November 2016 at the garage behind my house at 195 W Main St, Westminster MD 21157.
We will start work at 8:30 AM, but come whenever you can and stay as long as you like.
If you need directions contact me: 443-244-1347 or jim@gizmosart.com
Old 11-08-2016   #2
93 Vette
93 Vette's Avatar
Default Re: WAZOO WMD - Nov 12, 2016 - Westminster, MD
Shoot wish i could make it. We're scheduled to go to our place in WV this weekend. If something should change I'll let you know Jim.
Matt
Matt Glyder
"93 Vette"
1991 ZR-1 - Artic White/Red #1252
1991 ZR-1 - Dark Red Metallic/Saddle #1817
2018 Grand Sport Coupe - Admiral Blue/Red & Black
1988 Corvette Challenge Race Car - Red/Black #66 (Co-owner with Dad)
1993 LT1 Coupe - Arctic White/Black (SOLD 5/31/15)
93 Vette is offline   Reply With Quote
Old 11-09-2016   #3
Sure wish I lived a bit closer.
Old 11-09-2016   #4
George Maz
Definitely attending, thank you for the invite.
Just finishing up oil change today (24hr type). Car is properly aligned after second attempt. Hib's spare A-molds now on my car...diamond condition. Newer Verdestien tires all around thanks to member Ed Ramos.
Still a few items to sort out. Looking forward to the more experienced guys just checking over my car if time allows.
George Maz is offline   Reply With Quote
Old 11-09-2016   #5
Jim,
I'm picking up a set of injectors from Phil this Friday evening and will be at your place Saturday morning. I figure 3-4 hours to replace injectors.
Old 11-09-2016   #6
Arctic91
Arctic91's Avatar
Jim,
Sorry, but I'm going to miss this one! We'll be moving into our house (finally) here in Naples that day. Hope that you have a good turnout and I'll be looking for pictures!
Cheers,
Scott
Arctic91 is offline   Reply With Quote
Old 11-09-2016   #7
Ahomans
I will try to be there to help out. I am currently replacing the starter and if I don't screw up reconnecting all the little vacuum fittings everything should be good. If I do screw it up I will be there to understand what I did wrong. Yun's injector replacement should be helpful.
Al
Sent from my SM-T550 using ZR-1 Net Registry mobile app
Ahomans is offline   Reply With Quote
Old 11-09-2016   #8
dredgeguy
dredgeguy's Avatar
Hope to be there Jim. Might be on puppy duty and if so, might bring her with me.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 11-09-2016   #9
JFFerner
Hey Jim:
I'd like to come by with a request for advice. Alternator/battery concerns needing diagnosis. Of course there's always a drain on the battery, but this goes dead after 8-10 hours of just sitting. I tried disconnecting negative cable while engine was running to see if alternator operating or not, however engine continued to run.
And so it goes.. Jim F.
JFFerner is offline   Reply With Quote
Old 11-10-2016   #10
Roadster
Roadster's Avatar
Hi Jim, I can make on Saturday. Will be bringing a bakery buttercake, also a bag of crab chips, (which btw are very tasty) and whatever else you may need to keep this hungry group happy.....if you also need a case of water, just let me know.
I have a few items on my list, but as always no rush to get them done. It's just great to come down and hang out with everyone.
The list in no specific order or time table to complete.....
1. just purchased Hawk Brake pads for front & rear.
2. install Hurst shifter whenever....
3. do a plenum pull to address vacuum leak and maybe replace coils and vacuum lines....( I have both)
Again no biggie......will post later today on my status.......thanks.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
