Old 04-17-2009   #1
Default Header install tips and tricks??
Okay, my powder coated parts are suppose to be here today but UPS dropped the ball and I doubt I will see them until Monday
So, I might have time either tomorrow or sunday.. I am thinking of tackling the headers.. Brake booster it removed on the drivers side which may help.
I am looking for any/all tips and tricks to help..
the Z is sitting on a Kwiklift right now. if I dont have to remove the tires it might be better, but I will manage if that needs to be done
so open for any help
thanks
Old 04-17-2009   #2
Default Re: Header install tips and tricks??
I know I shouldn't speak to this because my headers are still in my living room, in the box!
....but when I was doing my shocks & had the wheel well liner panels out I was marveling at how I could actually see the exhaust manifold flange and how many bolts the factory couldn't get in!
The dipstick tube bracket may not work in the OE configuration.
Watch the steering shaft clearance.
Extensions for the O2 sensors.
Wrap the clutch hyd line from heat, and wrap any electricial lines from the heat, my thinking is the heat shields are now gone??
yea, pretty feeble! That's all I've come up with except for fitting the rest of the exhaust system to the collectors but I think that has to be done one a case by case deal.
Old 04-17-2009   #3
Jagdpanzer
Jagdpanzer's Avatar
Here are a couple of web sites I found useful when installing my headers last summer:
http://www.bcvettes.org/
http://www.pnwzr1.net/PNWZR1.htm
I can't imagin removing the stock exhaust or installing headers without taking wheel well liner panels out.
Old 04-17-2009   #4
jonszr1
jonszr1's Avatar
done 3 sets ,the hardest part is trying not to cut your hands on the heatshields when taking off the stk system . these are some of the easiest headers i have ever installed .just have some bengay for sore muscles from contorting
Old 04-17-2009   #5
Jagdpanzer
Jagdpanzer's Avatar
Be sure to clean the head bolt holes out very well so the new header bolts turn in as easy as possible. I used Stage 8 header bolts:
http://www.stage8.com/products_lhb.html
However, I did not feel it was necessary to install the locking tabs that came with the bolts. Summit has listing for a set of 32 bolts specifically for ZR-1:
http://store.summitracing.com/partde...8&autoview=sku
The small 12 point 8 mm head provided a little extra clearance in the harder to get at holes.
Old 04-17-2009   #6
I have gaskets, bolts and oil Dipstick bracket from Jeff vette..
Which side is more of a PITA?
Old 04-17-2009   #7
I can't imagine removing the stock exhaust or installing headers without taking wheel well liner panels out.
Agreed.
Old 04-18-2009   #8
How many little screws on each side for the HEat shield?
I see 4 ont he driver side.. that it?
Old 04-19-2009   #9
1 Down, 1 to go
Driver side is removed and Header is installed
I did not remove rear part of fender well, having the Brake Booster out helped a ton..
and the ROOM now.. WOW..
next header later today or this week..
Old 04-19-2009   #10
blackjack
dont forget to coat your bolts with some sort of sealant or anti-seize,as
aluminum and stainless dont fare well together ,especially in harsh environment
bj
blackjack is offline   Reply With Quote
