![]() Join Date: Apr 2013
I've noticed a couple times that my right headlight doesn't open when I turn the lights on. But it is intermittent. The motors were rebuilt right before I got the car, so I don't think they are the issue. Sometimes you can turn the lights off and back on once and it will work the second time. Last night it took me 3 tries one time, then the next they both worked first time. Any hints on what might be causing this? Switch? Or a connector somewhere?
Also - while I'm on here - usually takes 3 or 4 tries to get the e-brake to release and light to go off. Is there a trick to how or when you push the button when you pull the handle up to release it - or is there something in that system I need to lubricate? |
![]() Join Date: Apr 2004
On the e-brake, the grease gets old and hard causing the release latch to stick. Remove the cover clean the assembly and apply new grease. The hardest part is getting to the screw on the cover be sure to put down rags so you don't get the old stuff on the carpet.
I've got a dozen pics of headlight dis-assembly + sequences - gimme' an hour to dig them up from another computer.
If the nylon gear has a crack in it, you can rotate it 180'; problem solved. I did it waiting for a new gear, and the new gear is still on my shelf 6 months later... |
Have a show tomorrow - will be able to look at it then. Hoping it's just a connector since I know the motors/gears were just redone. Lights probably haven't cycled over 10-15 times since then.
Don't go spending a bunch of time looking YET - may be something fairly simple - was looking for ideas for when I can get the hood up and look at it... ![]() As to the e-brake - I will clean and re grease. Do you guys know if it matters WHEN you push in the button? As in before you move it, after you move it, when it gets tight, etc.? |
![]() Join Date: May 2013
Racinfan, I always pull up on the handle slightly before pushing in the button. It makes the release much easier and takes the tension off the release mechanism.
#6 | |
On my 91', when I disconnected/reconnected the battery, I could hear the headlights' motors gears slipping and clanking. This is a simple test to figure out if there is a mechanical problem. Do they make any noises when the lights pop out from the hood?
#8 | ||
The cracked nylon wasn't taking the worm drive to the Limit Contact, and it was killing the battery. But here's some stuff for open / close failure: (I'm not patronizing you here OP; that guy I was helping had zero tech inclination) Quote:
#9 | |
The rest:
#10 |
Guys - that is AWESOME info! I will be checking this all out!
