Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 02-13-2013   #1
Daniel_Mc
Daniel_Mc's Avatar
Default C7 Wreck
Already...
http://autos.yahoo.com/blogs/motoram...011152790.html
Old 02-13-2013   #2
Default Re: C7 Wreck
Well thats one way to park to pull over to pee I guess?
Old 02-13-2013   #3
scottfab
scottfab's Avatar
I was just getting on to post the same thing.
Found it in a different place though
http://www.corvetteblogger.com/2013/...es-in-arizona/
Scott
Old 02-13-2013   #4
Fully Vetted
Fully Vetted's Avatar
...I was just getting on to post the same thing.
So was I!
I knew they should've gone with wider tires.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 02-13-2013   #5
efnfast
I hate when that happens!!
Old 02-13-2013   #6
looks like they tagged both sides of the car
Old 02-15-2013   #7
ZR-1 Franz
Seems to be as if Corvette test drivers aren't any longer what they used to be!
May be he wanted to test a new park assistent! I mean these stupid electronic
assistents which take the steering wheel out of your hands.
Franz
ZR-1 Franz is offline   Reply With Quote
Old 02-15-2013   #8
Here's what someone suggested would "probably" be part of the official accident report:
"We find that the C7's flat spin was induced by the disruption of airflow into the starboard vent. This disruption stalled the engine, which produced enough yaw rate to induce a spin which was...unrecoverable.
There was no way the driver could either see or avoid the jet wash which produced the engine stall. Therefore, the board of inquiry finds that the driver was not at fault in the accident of 02 February. The driver's record will be cleared of this incident. The driver is restored to drive status without further delay. These proceedings are closed."
Old 02-15-2013   #9
i see what you did there
Old 02-15-2013   #10
Paul in SC
Paul in SC's Avatar
All the more reason for a mid-engine LT5. Better balance.
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
