Old 03-10-2013   #1
Brad Sewell
Default PCV Vacuum connection to dual connecter
Does the metal vacuum tube plug directly into the connector or is there a rubber hose between the two?
Thanks.
Brad Sewell is offline   Reply With Quote
Old 03-10-2013   #2
vilant
Default Re: PCV Vacuum connection to dual connecter
If your talking about the dual connection on the plenum, under the throttle cable assembly. On 1990's there's a rubber block that has the plastic tubes on one side and the other side plugs directly into the plenum connectors. This was eliminated on later year models, I believe, so I don't know the set up on later years.
Old 03-10-2013   #3
Brad Sewell
Thanks Joe.
I'm talking about the pcv connection under the map sensor -- the connector that Jerry's Gaskets is re-making for our availability. Should it have this rubber hose connector in the middle? Or should the metal vacuum tube plug directly into the check valve connector?
Old 03-10-2013   #4
vilant
Well, mine plugs right into it the metal tube with no intermediary rubber hose.
