Old 02-11-2021   #1
Corvette95
Corvette95's Avatar
Default Adjustable aluminum gas pedal installed.
Didn't want to modify the car so I ordered an adjustable aluminum gas pedal cover. Will (hopefully) make heel/toe easier. Wasn't a quick install due to the room in the drivers floor board (you all know what I am talking about) but about 20 minutes. Raining today so no test drive yet.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-11-2021   #2
Erik
Default Re: Adjustable aluminum gas pedal installed.
That's very slick. Nice heel and toe mod. I can't imagine all 6'4 of me working down there.
1990 ZR-1 # 996
Old 02-11-2021   #3
Very nice!
How is it attached to factory pedal?
Old 02-11-2021   #4
Corvette95
Corvette95's Avatar
Very nice!
There is a back plate behind the pedal, and two bendable metal straps that fit very tight around top and bottom of pedal...attached by 5mm torx screws. Then on the front the actual aluminum plate) there for 5 torx bolts of different lengths and different size spacers (depending on if you want the pedal at factory depth or closer to front of seat, 3 sizes to choose from, then one torx that you can adjust the fan splade to the width from the brake to gas pedal. It is very secure, and it fits the Corvette fine, but it is the maximum width of the supplied bands. I am going to drive it and see if I chose the right spacing, I went for maximum length spacers. I think it was around $60 and it can be removed for the stock look if wanted.
Old 02-11-2021   #5
Appreciate detailed description.
Old 02-19-2021   #6
VikingTrad3r
where did u find this?
VikingTrad3r is offline   Reply With Quote
Old 02-19-2021   #7
Corvette95
Corvette95's Avatar
Razo RP82A
Old 02-19-2021   #8
Prez1967
Its not pretty but it seems like a great concept! Please let me know how it works. I've installed Razo pedals in the past. Never had any issues. Also bent some pedal assemblies to accomplish the same end goal that you were after. I wonder how solid that locking nut is. May want to throw some loctite on there if you havent
1994 #353 "Bluey"
Prez1967 is offline   Reply With Quote
Old 02-19-2021   #9
rkreigh
I broke the stock plastic mount and like this idea
Old 02-20-2021   #10
HAWAIIZR-1's Avatar
https://www.goengineer.com/blog/3d-p...as-pedal-mount
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
