Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 10-10-2011   #1
Dime
Default Wheel cleaner
I've got polished (not painted, not chromed) a-molds, and regular car soap and elbow gress isn't working. Any suggestions?
Dime is offline   Reply With Quote
Old 10-10-2011   #2
Default Re: Wheel cleaner
what are you trying to do to them? clean? shine?
Old 10-10-2011   #3
Dylan@Adams
Dylan@Adams's Avatar
You're best choice is a ph neutral soap for maintenance cleaning, so you've been doing right by sticking with that. Heavier chemicals will cloud/discolor polished aluminum faster than you can blink so you have to be very careful.
That being said, what specifically isn't working about the soap/water? Do you have heavier brake dust contamination or some other problem?
Dylan@Adams is offline   Reply With Quote
Old 10-10-2011   #4
Dime
Both
Yeah, the idea of using chemicals bothered me. I bought a bottle of mothers wheel cleaner, and before I used it I decided to look up some reviews and one mentioned it discoloring the wheel. Needless to say, it's going back to walmart.
A little bit of break dust, but what's really not coming off is what looks like water spots. Corrosion maybe?
Old 10-10-2011   #5
Originally Posted by Dime View Post
Both
you can check out www.autopia.org and see what people are using and ask questions. it's the cats meow of detailing forums
Old 10-11-2011   #6
Dylan@Adams
Both
You can actually try claying if its just surface contamination. A lot of times that will remedy it. Don't need any specific clay... whatever type you currently use for your paint - break off a chunk and go at your wheels with it.
Follow up with a quick polishing to shine them up and finish off with your preferred wax. That'll keep them shining and easier to clean as well.
