Old 09-26-2011   #1
rhipsher
rhipsher's Avatar
Default Another little suprise.
This is probably why I've had dash light disco instead of beach blanket bingo. I kill myself sometimes. Lol!
Man that connector crumbled like king tuts underwear. Seems like 80% of the time the Oriellys right down the street has everything I need. So it was time to install a new plug.
Just like factory new now.
I was hoping to be close to done tonight until I had to take car of the alternator plug. Oh well.
Old 09-27-2011   #2
a1991zr1
Default Re: Another little suprise.
I have had to replace that too while you are there might as well check alt and replace belt and tensioner. these items tend not to enjoy high revolutions. And these parts are fairly inexpensive. I would at least test the altenator and make sure you did not damage a diode.
a1991zr1 is offline   Reply With Quote
Old 09-27-2011   #3
batchman
Hoping that's heat-shrink tape and not just electrical tape (which tends to degrade with time/temp).
Humbly suggest that those splices sure look like good spot for some good old fashioned tin-lead solder.
Also betting I should take a look at ours - another point to inspect...
Best of luck,
- Jeff
Old 09-27-2011   #4
rhipsher
rhipsher's Avatar
Nope just electrical tape. Wraped each wire then wraped all three together and stuffed them back in the main. I'm not worried about it because honestly at some point that whole wire harness is gonna have to be replaced. All those wires in the loom are as hard as a rock and just plain wore out. The engine compartment is a harsh enviornment for wires. The wire harnesess everywhere else are in great shape. But that one that the alternator plug comes out of sits in a part of the engine thats exposed to the most heat.
Old 09-27-2011   #5
Blue Flame Restorations
Heat shrink is a quick and easy thing to do. Better safe than sorry. JMO
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 09-27-2011   #6
Concur and King Tut would approve
