Go Back   ZR-1 Net Registry Forums > General > Forum News
Old 04-20-2011   #1
bdw18_123
Default Website loading issues?
Anyone else having issues loading this forum lately?
Lately, I've been having a lot of trouble with not being able to load it, and "website taking too long to respond" messages coming up. Usually happens later at night like around say 10-12pm (just last night around that time it happened, when I was trying to post an update), sometime other times too.
I know it's not my computer because other websites work fine when that happens. Is the website being worked on or something?
Nothing more annoying than websites that refuse to load...
Old 04-20-2011   #2
Aurora40
Aurora40's Avatar
Default Re: Website loading issues?
Yes, the last two days I've had some serious lag and/or failing to load.
Old 04-23-2011   #3
zr1mom
zr1mom's Avatar
Several days ago I was getting a lot of database errors from this site. Not sure why. Since then I haven't seen any further errors so I'm assuming it was something on the providers end and hope all is ok again.
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 04-24-2011   #4
I can't access the forum either from my ISP @ home
Only can access it via my iPhone
Old 04-24-2011   #5
zr1mom
zr1mom's Avatar
I tried everything including Formating my hard drive on one computer and reinstalling a newer version of WINDOWS. As well as disconnecting my router and going directly through the modem. See my post # 3 above
This detective work also included having a Forum Moderator check if my specific IP address was blocked which he said it wasn't
It appears that it all has to do with a specific IP address which appears has everything to do with this Web Site. I say Appears because all of a sudden my CLEARWIRE ISP with that non workable IP address (for this Forum ONLY) starting working again after three of four days
I have to get an IPhone
You are working now because I got your ip address unblocked last night. Our provider had your ip address blocked for too many connects. So you are all set again.
ZR-1 Mom
Founder ZR-1 Net
Old 04-24-2011   #6
zr1mom
zr1mom's Avatar
Dave I'm checking to see if you are blocked also.
ZR-1 Mom
Founder ZR-1 Net
Old 04-24-2011   #7
zr1mom
zr1mom's Avatar
Dave sent them what I thought was your ip address and they said it wasn't blocked. Just to make sure I had the right one send me your ip address so I can double check.
ZR-1 Mom
Founder ZR-1 Net
Old 04-24-2011   #8
That ip is likely for my iPhone. When I get home later, I'll send you my ip
Thanks!
Old 04-24-2011   #9
Aurora40
Aurora40's Avatar
Did they mention what the limit or rate that they consider "too many" is? Can this happen if you browse the forum like a maniac?
Old 04-24-2011   #10
Dave
I emailed you my ip
I'm concerned that other people are having issues and just giving up. Maybe they aren't frequent users and figure our site / forum went away?
Hmmmmmmmmm
