I would like to buy a screw and the two crescent shaped washers that attach the throttle position sensor to the LT5.
Please help!!!! |
http://www.whiteracingproducts.com/i...roducts_id=301
I have the full throttle body screw rebuild kit in stock. |
can you not match these in the machine screw drawers at home depot or lowes? How about fastenal?
![]() Join Date: Jul 2010
Can you get this from GM?
17112266 GM MRSP is $52.84, GM parts direct $29.06. peace Hog |
![]() Join Date: Dec 2003
This is a really odd-duck screw. I could find someting close that would screw in, but the diameter was really too small and the thread pitch was off. it didn't conform to SAE or Metric.
I have a couple in stock. http://jerrysgaskets.com/store2/root...roducts_id=164 ![]()
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-11-2011 at 11:35 AM. |
![]() Join Date: Mar 2007
Jerry
Pitch seem to be around 0,7-0,8. A M5x0,8 or a fine threaded M6x0,75 looks to be close from that pic. |
That's the problem with this particular screw, it's around/about & close, but nothing standard for metric or SAE actually matches the pitch & diameter.
#10 |
