#21 |
![]() Join Date: Jan 2024
Subfixer, did you need to do any modifications to get these pumps to fit into the sending unit? I received the kit from Lingenfetler and all ways going smoothly until trying to slide the new pumps into the frame.
My stock pumps measure ~36.75mm in width. StockPump.jpg The Walbro GSS340 pumps I received from Lingenfelter in the high flow kit measure ~39.18mm in width and will NOT push into the holder. WalbroGSS430G3.jpg https://walbrofuelpumps.com/255lph-w...pump.html.html I don't see how these are going to go in without cutting a slit in the side of the frame for each pump, then praying to the zip-tie gods it holds together. Last edited by scorp508; 07-19-2024 at 01:54 PM. |
#22 |
![]() Join Date: Sep 2018
Yes. I split the holder down one side. Secured with tie wraps.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
