Old 09-27-2020   #41
Macroblock
Macroblock's Avatar
Default Re: ECM Issues - No Start
Just an update to provide this link on troubleshooting the C4-ZR1-ECM:
http://zr1ecm.com/youfix.html
Macroblock is offline   Reply With Quote
Old 09-27-2020   #42
Nice. Will you be going into more detail on the internals of the ECM? I have one I need to fix, I should probably pull it apart and look at the solder joints first.
Lastly these are conformal coated aren't they, what is the best way to remove the coating to get to the pins?
Old 10-03-2024   #43
Macroblock
Macroblock's Avatar
Default ECM Issues - No Start
I normally use Acetone on a Q-Tip to remove the Conformal from the pins.
