-   -   Need advice for battery replacement (http://zr1.net/forum/showthread.php?t=8288)
LuxZ 04-08-2009 03:02 PM
Hi all,
May be you can help?
My battery ac delco is dead (strange to me as it was electrically fed during the whole winter times, no ?), and the Chevrolet dealer in Luxembourg does not have any similar battery available, same as all dealers in Europe, and because the official corvette importation company went bankrupt...
My current dead battery shows the following reference 75 5MF and 550 CCA. it is not the original battery but I assume it has the correct characteristics fro my 1994 ZR1
My Chevrolet dealer can only provide me with a none delco but similar size battery with 460 CCA as single reference
Is 460 CCA enough and harmless for engine start or should I better order myself directly an ac delco with 550 CCA from the USA?
Thanks for your support
GOLDCYLON 04-08-2009 03:24 PM
Re: Need advice for battery replacement
I would order I higher CCA battery
HAWAIIZR-1 04-09-2009 02:09 AM
I agree :thumbsup:
LuxZ 04-09-2009 05:10 AM
Thank you all,
ok, I will do it this way then; better wait a little bit and have the right battery
Jeffvette 04-09-2009 05:19 AM
Originally Posted by LuxZ (Post 58594)
Thank you all,
You might try locating a braille battery or an odyssey. Both should have Euro retailers, they are lighter weight and more compact.
dbriana 04-10-2009 10:58 AM
Originally Posted by LuxZ (Post 58522)
Hi all,
I believe 690 CCA is the original requirement/spec.
LuxZ 04-13-2009 05:02 AM
Thank you dbriana
ok, so 460 CCA would definitely be way too weak to start the engine properly, should it not start at once. I am out for holiday at the moment and forgot to take the original (maximum) battery dimensions. So unless anyone has such dimensions in mind, I will wait to return home to get those figure qnd try to find the right replacement battery.
Thanks again
http://www.zr1netregistry.com/forum/...s/thumbsup.gif
LuxZ 05-08-2009 12:00 PM
Hi there
I eventually got an Xtreme battery with same dimensions and connectivities, and original 690 CCA as well. It is a sub-brand of APEX if I am correct. It works fine
Thanks again for your help
