-   -   HELP No power ( electrical) (http://zr1.net/forum/showthread.php?t=8212)
SignMan59 03-30-2009 07:07 PM
Ok Ive had the car a month or so. We had it out for a short drive, and shine. Everything was peachy. We put it away in the garage a couple weeks ago, havent touched it since. Went to go start it today and ZERO juice. Not even a dim courtesy light. Its like its "locked out" of power or something. I cant see where anything was left on.
Is there something ive done that shut down the system? Or what should I look for?
:confused:
QB93Z 03-30-2009 07:52 PM
Re: HELP No power ( electrical)
My guess is that your battery is dead (DOA).
Use a battery charger to charge the battery and then take the car to a place that can test the battery capacity.
Even a "charged" battery (one that measures greater that 12 volts) can have a very low capacity. That means that a small amount of load will quickly drain the battery (lower the voltage) until it will not be able to start the car.
Good luck
GrayZ 03-30-2009 09:21 PM
:iamwithst:iamwithst:iamwithst or i am stupid, i forget... :dontknow:
GOLDCYLON 03-30-2009 09:22 PM
I agree my money is on a bad battery as well. Maybe an internal short as well. If you dont drive it often I suggest a battery tender to maintain a healthly charging system.
ZZZZZR1 03-30-2009 09:25 PM
:confused:
You didn't "wash" the motor did you? :)
If not, the battery is a quick check.
:thumbsup:
SignMan59 03-30-2009 10:13 PM
DOH!! (Homer Simpson) Well it WAS the battery. It went from perfectly fine....its only 2 years old.....to a complete open circuit. The car only has a few thousand miles on it and its rarely started, and I guess that takes its toll on the battery. I'll be getting a battery tender.
Im glad it was the battery....I figured triggered an internal anti theft circuit or something, mickey mousing around with the detailing of the engine compartment. I never had a battery go from strong to dead like that so quick.
Anyway....thanks for the responses.
Paul Workman 03-31-2009 03:42 AM
Ummmyeeeaaaahhh...But! I'd wanna check the static current drain anywayz. I believe mine draws around 25mA that keeps the "pooter" alive, but I'll check it and get back to ya. In any case, as little as a single courtesy light can take a battery to zero in a couple weeks time. And, I totally agree on the Battery Tender. Winter or summer, it is always topped off and ready for serious cold starting.:thumbsup:
P.
