-   -   spark plugs (http://zr1.net/forum/showthread.php?t=5761)
RUSSELL 05-21-2008 10:39 PM
spark plugs
got a hesitation problem at 1500 rpm or so going to change plug
what are a good replacement for factory ones ant info or advice.
-=Jeff=- 05-21-2008 10:54 PM
Re: spark plugs
AC Delco 41602 are what I just installed in mine
bradslt5 05-21-2008 11:31 PM
Re: spark plugs
I USE THE DENSO IRRIDIUMS NOT SURE OF THE NUMBER . THE IRRIDIUMS SEEM TO BURN BETTER TO ME
karterdon 05-27-2008 09:17 PM
Re: spark plugs
In my 91 - I used the NKG Iridium - Part Number - BKR5EIX use the GM Factory gap = .035" Not necessary to go larger. Also don't forget to use a little anti-sieze on the threads before you install them.
Don Yoakem
91-#267
Dark Red Met.
