Vehicle Speed Sensor
In preparing to put in 4:10s this winter, I came across some tech notes about changing the speed sensor in the transmission. What exactly are the parts needed, and where is the place to get them?
Re: Vehicle Speed Sensor
Marc Haibeck carries them.
I had to do this when I bought mine. You basically need a new VSS drive gear (little plastic thing) this goes inside where the speedo connector attaches on the gearbox.
It's a relatively small job in itself, the difficulty comes from the fact that you need to take the exhaust off to get access and sometimes disconnect the drive shaft. Not an easy job if you dont have a good way to get underneath. I didn't and took it to a dealer who ripped me of completely. :mad: |
