Wanted: Valeo Clutch
Probably a long shot, but does anybody have a Valeo clutch available for sale? Either with the original thicker pressure plate or the thinner later type.
I am looking for the full kit, pressure plate, clutch disc and bearing. Thanks |
Re: Wanted: Valeo Clutch
The newer version are available on rockauto based on your year.
Unfortunately not genuine valeo, they are the cheap Chinese copies even though they are packaged by valeo. I would like to try to find an original valeo pressure plate, which has valeo stamped into the casting.
The clutch I have taken off my car is one of the Chinese ones and has prematurely failed. Ideally I would like to find a new original kit or maybe a used pressure plate and a disc that I can get refurbished. But will also need the bearing and pressure plate bolts too Thanks |
Take a look on Jegs, they have McLeod that look pretty good.
