FS 1990 Haibeck 402
Here you go guys! This car is #2752 and has a Haibeck 402 with less than 600 miles on it.
1990 ZR-1 Corvette 40,3xx on the chassis maybe a couple hundred on the fresh engine 402ci engine assembled by Marc Haibeck and installed at his shop Ported tb, ported heads (38mm), ported plenum (38mm), headers, B&B exhaust Stock trans/gears SPEC Kevlar stage 2 clutch Lightweight flywheel (revs super-fast, incredible) Fluidyne radiator/oil cooler Coilover shocks, urethane bushings all around, adjustable swaybars Wilwood Grand National 6-piston front brakes, Wilwood Superlite 4-piston rears Adjustable brake-bias knob under steering wheel CCW Classic wheels black centers with polished lips 18x12 front, 18x13 rears, 335/30/18 Toyo R888Rs brand new on car. Rollbar, G-Force harness, etc. Boatload of spares with the car including a full set of CCWs (old tires), stock parts, brakes, coilovers, etc. Photos will be added when I figure out how to not exceed my limit. $27,500 Motivated Seller. Someone is going to get a great deal! If you want photos. Text me. Call or Text 608-778- seven five 2 niner |
Re: FS 1990 Haibeck 402
All three of your cars are priced attractively for what they offer. I?m sure the Pete P 441 is a beast. I?d lean toward this one, personally, but you can?t go wrong with any of them. Good luck with the sale.
TTT
Sold!
