-   -   No start help!! (http://zr1.net/forum/showthread.php?t=34964)
EddieGTO 09-21-2023 11:18 PM
No start help!!
I have a strange problem?
I ordered up all new injectors from FIC and installed them, fun stuff. Took my time, disconnected the battery and everything.
No I have a no start problem. Pretty sure it?s not the injectors, I smell fuel and had a fuel pressure gauge on the rail, shows a drop in pressure as it cranks.
Put a coil tester online with a spark plug? no spark!
Pull the plenum back off to check all my connections, even took them off to make sure no bad connectors, put back together. Still no start.
No codes come up, fuses are good, key on, security light is off?.
What am I missing?
Please help!
phrogs 09-22-2023 12:36 AM
Re: No start help!!
You're positive everything is plugged in?
Check for bent pin on the ignition module that pain in the *** that's on the plenum.
EddieGTO 09-22-2023 02:25 AM
Re: No start help!!
Checked everything. May have to pull it apart a third time!!
XfireZ51 09-22-2023 11:20 AM
Re: No start help!!
Welcome to the brotherhood. Been there done that.
geezer 09-22-2023 07:22 PM
Re: No start help!!
As Phrogs Said Double check the pins on the Ign. Module !!
tccrab 09-23-2023 01:55 AM
Re: No start help!!
Just in case it's not entirely clear, the ignition module is the device that lives on the bottom side of the plenum.
It's also known as the DIS module.
It has connectors in front and the back. It's very easy to bend a connection pin on either of the plugs, especially the one on the back.
Suffice to say, it is a serious design flaw, that really should never made it into production.
Given all the other stuff going on under the plenum, it's the only thing that will stop the coils from firing.
Good luck!!
Crabs
wfot 09-26-2023 01:31 PM
Re: No start help!!
Check inj 1 fuse, is it blown?
If yes, you may have pinched an injector wire in between the upper and lower plenum.
Start there, a dead inj 1 fuse signifies a grounded hot wire to the injectors, coils, control module.. easy check
viper107 09-27-2023 11:10 AM
Re: No start help!!
its definatly somthing you had your hands on,so back apart you go
