WTB: ZR-1 Radio Antenna Bezel / Grommet *BOUGHT*
Looking for a replacement ZR-1 antenna bezel. Does anyone have an extra that they would part with?
Had to replace my antenna and learned the hard way that apparently this is a ZR-1 specific part. -Jackson |
Re: WTB - ZR-1 Radio Antenna Bezel / Grommet
I have one but what happened to yours if I may ask?
I had a broken antenna mast...instructions on the new one said to remove the grommet in order to replace the mast with the antenna unit remaining in the car. I had purchased a replacement grommet online since I figured it might break apart when removing, and it did. Unfortunately, when I was finished replacing the antenna mast, I discovered that all of the replacement grommets online are for standard C4's.
I will send you a PM about the one you have. |
How do you determine the difference standard C-4 verses ZR1? Part #?
Reason I ask is I might have one. |
https://www.zr1.net/forum/attachment...6&d=1595865040 If it's in its original GM parts bag, the part number is 14104620, I believe. |
They are slightly different due to the ZR-1s wide ***.
Well I dug out the one I have in my stash and mind you it came from a ZR-1 But it looks like the normal car version so I assume someone replaced it with the base car version. I guess I didn't notice at the time.
sorry It's not the right one. I have another one but its still on the car and I haven't parted out yet. |
Antenna grommet for ZR-1 has less slant angle on top because antenna location on rear fender is relatively flat on ZR-1s. They are different.
Once the OP gets their grommet, I need one too if there is another floating around.
3 Attachment(s)
