WTB: 1990 ZR-1 ECM
Looking for an E.C.M. car is running rough and when tapping on the unit it runs smooth for a short time, then back to rough.
Sent from my SM-G960U using ZR-1 Net Registry mobile app |
Re: 1990 ZR-1 E.C.M.
I have a few available.
1 Attachment(s)
Sweet! How much, and how do I go about getting one? These are the codes for mine.Attachment 19336
ECM's usually sell for close to 2k make me an offer. Are you sure you need one they usually don't go bad.
I suggest first disconnecting the battery. Then carefully remove and reseat each electrical connector on the ECM - check for corrosion. Also remove and reseat the cal pack (chip). See if that helps before plunking down the money for another ECM.
Re: WTB: 1990 ZR-1 ECM
