-   -   '94 ZR-1 Engine/Car Rebuild (http://zr1.net/forum/showthread.php?t=31088)
albeR/To 10-24-2019 12:42 PM
Hello Everybody!
After like two years since I bought the car from Kris and less than 10 miles behind the wheel (the car was impounded after few kilometers away from the customs office and after 3 days in italy because of expired temporary license plates and it costed me a "small fortune" to get it back) I decided to begin a big overhaul of the car.
I started immediately by fixing some small issues around the car, but everytime I removed something I found something worse behind it...
At the end a couple of month ago I decided to remove the engine and start from everything from scratch.
In this thread I will share my experience/story of the rebuild of the car and I hope to find some help from you guys.
https://i.ibb.co/4sQzJdv/20170928-141405.jpg
When I got stopped by the police...
https://i.ibb.co/kHkbw3H/20180218-162755.jpg
When it arrived at home
https://i.ibb.co/1LQV7g3/20171009-184055.jpg
At the workshop with one of its sisters
https://i.ibb.co/dMRz2CV/20190822-172051.jpg
The engine just before the removal
https://i.ibb.co/xSBmF09/20190822-181440.jpg
Almost ready to be removed
https://i.ibb.co/C6JyXKj/20190823-190510.jpg
The engine is on the ground!
https://i.ibb.co/N7cZRpK/20191016-141313.jpg
Lets the nightmare begin
https://i.ibb.co/GdjNyJn/20191016-152243.jpg
First surprise: camshaft lobe tips are ruined (seems like pitting)
https://i.ibb.co/ZzqNnJZ/20191016-152238.jpg
On both banks
https://i.ibb.co/wWX9nvS/20191028-115928.jpg
Crankshaft doesn't look bad
albeR/To 10-24-2019 12:49 PM
Re: '94 ZR-1 Engine/Car Rebuild
Now I'm already stuck...can you suggest me the way to remove the spacer on the crankshafts between the chains sprocket and the oil pump?
grahambehan 10-24-2019 04:37 PM
If you have the sprocket removed, the spacer is a slip fit and should be able to be rotated and pulled forward off the crank.
Graham
jss06c6 10-24-2019 08:12 PM
Wish I could see your pictures, but unfortunately cannot. Keep at it, it's worth the effort.[emoji41]
Steve
Sent from my SM-G950U using ZR-1 Net Registry mobile app
albeR/To 10-25-2019 05:21 PM
Graham
I removed the sprocket, but the spacer doesn't seem it wants to move...the spline also seems stuck...on monday I will try again.
Steve
I will use a different pictures host (I used Microsoft onecloud, but it doesn't seem to work)
albeR/To 10-28-2019 09:40 AM
https://i.ibb.co/31VL006/20191028-120252.jpg
Main bearings completely gone
https://i.ibb.co/hmR5ycj/20191016-184546.jpg
Pistons are ok, just a lot of dirt on them
G8nightman 10-28-2019 09:58 AM
You need to resize those pictures
XfireZ51 10-28-2019 12:09 PM
Alberto,
Sono stato a Salo e Sirmione molti anni fa con famiglia. Bellissimo.
BigJohn 10-28-2019 12:41 PM
Molto cool Italiano
S.hafsmo 10-28-2019 03:36 PM
What caused you to remove the engine in the first place? I seem to have missed the background story. What could have wreaked havoc in the entire engine?
