-   -   Noise after turning off headlights / parking lights (http://zr1.net/forum/showthread.php?t=2684)
turboimpala 01-15-2007 05:41 PM
When I turn off my head lights or even just the parking lights there is a clicking noise somewhere under the hood.
Quite noticeable maybe 5-10 clicks.
Anyone have any idea what that is?
Is it normal?
Thanks.
jonszr1 01-15-2007 06:45 PM
Re: Noise after turning off headlights / parking lights
It could be the headlight motor starting to go. open the hood and have a friend turn youhead light on then off . you should be able to locate the noise from that . hope that helps.
WB9MCW 01-15-2007 07:03 PM
Hey Turbodid you see that our new prez answered your ? on drag slicks in your post on that item??? I see that he is selling his turbo V6 car as well...I had sent him a PM so u could hook up with him and learn more from all exp with the turbo's v6...go back and check out the thread...If yo make a reply post there it will trigger his thread tracker and he will see your post.
Jeffvette 01-15-2007 07:41 PM
More than likely not the motor, but the actual gear iteself or also the bushings may have deteriorated.
turboimpala 01-15-2007 07:44 PM
Yes I saw his reply thanks.
turboimpala 01-15-2007 07:45 PM
What's strange to me is that if I turn on the parking lights only, then turn them off, I still hear the noise. Does that make sense considering the headlights were not turned on in the first place?
Corvette95 01-16-2007 12:04 AM
yep...headlight bushings.
