Silly power key question
I have been thinking about keeping my power key but adding a big red switch ala the Men In Black Ford. I not really wanting to replace the key with the switch but just supplement it. It seems like it would be pretty easy to do but I am conceded that the added resistance of the switch and the potential current spike associated with energizing it may harm the ECU. Has anyone ever tried anything like this?
Re: Silly power key question
sounds like a cool idea. What happens when you turn the switch on at 5k WOT? is it like hitting the nitros switch?
The owners manual recomends not to do it over 4K
Just mulling this a little bit...
There are several ways that come to mind, depending on the MY. The 90s would be a little more complicated, but the later models would be quite easy. The 90s switch (RED BUTTON) would work if the button itself were actually a sequential "ON-OFF" mechanical type; essentially performing the duties of the existing key-activated switch (to sustain the completed circuit). Or, the sequencing could be toggled electronically (solid state). The later (91+ MY) could be done with a momentary "ON" button - in parallel with the existing dash key-switch "ON" switch mode. I'll take Steve's word for it when he says the manual doesn't recommend switching to FULL POWER (switching from NORMAL to FULL POWER) above 4000 rpm: outside the discussion anyway, but there must be a reason. Added resistance by adding a switch would be negligible - a non-issue. And, there wouldn't be any additional concern of inductive voltage spikes unless inductive reactant components are somehow included in the latching circuit for some reason. But! Besides all that... until the operating conditions were met, the secondaries wouldn't be signaled on by the ECM, anyway; button or no. And, once up to temperature, the engine is still under the control of the throttle body...button or no. So, to me (at the risk of being obtuse), such a button seems so unnecessary to the point of being silly, especially if the car is modded (as many are) to run w/ the secondaries on full time already. (The secondaries are on essentially full time, so what is the RED BUTTON to do?) ...Just sayin. |
Why just not bypass the switch with the harness or at the prom level like most of us have done? Full power always... No key or switch required
And Elvis never Died.... He just went home |
My initial thought was it would just be a novelty. Regarding bypassing the key, I prefer to keep the key active.
