electric cut out questions
What are the recommended locations for installing the switch?
What's the best way to run the wire from the cut out actuators to the switch? |
Re: electric cut out questions
5 Attachment(s)
When Marc first did mine (cutouts in the middle, no spare) he installed the toggle switch that came with the cutouts from QTP left of the console under the knee bolster. I could not reach it and it was stiff anyway. So I searched out a rocker switch and hid it under the carpet on the passenger side of the console within easy reach. As you know I also copied Tony Davila and had Marc move the cutouts to right in front of the mufflers and restore the spare carrier. Marc did the original switch wiring in through the driver side compartment behind the seat then along the driver side sill and up under the knee bolster. I did not change the wiring route when I installed the rocker switch as there was enough extra to tie in. I thought you might be able to run it down the console and through the panel at the seat back but Marc said this is more difficult for some reason; I don't know why. Here is a copy of the email I sent to Marc when I did the switch switch (ha ha) with pictures. Hope that helps. --Bob ------------------ Hi Marc--While I know the cutout switch you installed works for others, it just did not work for me. I could not reach it when I was driving and I could only push it up (open), not down, even when I was stopped. Not enough room to grab it and pull down. So I went back to plan B and installed the rocker switch under the carpet on the right side of the transmission tunnel. I have attached some pictures below. You might want to consider this as an alternative to the current switch and location if you are doing another cutout install. It is hidden but you can reach it and activate it while you are driving. The carpet is a bit stiff but I can still feel it and activate it easily. It is just slightly below the edge of the plastic console trim. There is plenty of room for the switch even with spade connectors. It really doesn't take much longer than drilling the hole and you can avoid the time to solder the connections. You also don't have to take off the driver's side trim panel and can probably route the wires up the center console and leave the excess wire in the ABS compartment (I left your routing in place). Once the trim plates are off you can see where the best place is for it. Had to pull down the right side knee bolster panel and lose the three little staples holding the carpet to the top of the plastic trans tunnel side. It is a little more difficult to cut a rectangular opening but I did it by drawing a template for the hole (about 1-1/2” by about 13/16”) on an adhesive label. Drilled a bunch of small (1/16) holes to outline the hole, then some larger ones. After that I used a small metal cutting jigsaw blade mounted in a handle (which usually holds a larger hacksaw blade for hand cutting). Worked great. Finished with a flat file. I see why you soldered the connectors to get clearance but I reverted to spade connectors. Plenty of room for the long connector tail. The switch is the same one I gave you, a Gama Electronics DPDT momentary with spade connectors. Spade connectors exactly match those of the QTP switch. Here is a link: http://www.gamainc.com/site/epage/130245_941.htm. About $10 retail. Best, Bob Switch install pix: |
2 Attachment(s)
Here is a picture of the cutouts themselves and the final finished cabin. I actually cover the switch location itself with about a 2"x2" square of adhesive clear plastic so my dirty fingers don't spoil the carpet. I use the same stuff on the console to the right of the accelerator pedal to minimize wear on the carpet. It's the stuff you buy at Home Depot in a 24" roll to cover carpet. --Bob
Thanks for the reply, Bob ... I was hoping you would chime in. Your info is what I needed ... very helpful.
Shame on you George and Bob; you guys are gonna make it get some cutouts too! I can't believe I did not listen to Bob's while at BG this year!!! That really sucks when I had the chance.
Here is my cut-out switch on the right side of the under dash panel, its a little crooked - need to fix that next time I'm in there but I find this location works pretty well.
http://i418.photobucket.com/albums/p...8/IMG_0788.jpg |
