Oil leak help...
Oil leak on pass side of the block I think it may be this sensor near oil dipstick? Any idea what this sensor is? Does this typically leak oil or probable it's something else leaking? I have about 40k miles on my 90.
Thanks much! |
Re: Oil leak help...
Header stud
Potential Oil Leaks and the OPRV Cover Plate |
2 Attachment(s)
thanks all, I will put it back up on the lift and take another look.. its tight up there! I cant tell exactly where it is coming from but looks like its from that switch..
Here are some pictures I snapped when it was on the lift. Does anyone happen to have the PN for that switch? I am thinking if I get this back up on the lift I might as well replace it.. I assume its an O-ring behind the switch assembly?? I am having problems finding this sensor or info about it online or with forum searches? |
When I look online I find this sensor: http://www.ecklerscorvette.com/corve...1990-1995.html
Yet I believe this one is closer (however mine is all plastic): http://www.ebay.com/itm/Engine-Oil-L...96a594&vxp=mtr |
Your looking for "oil pressure switch".
Jerrys Gaskets can set you up
This is the Oil Pressure Switch if that is what you need.
http://www.jerrysgaskets.com/switch-...new-90-95-9b3/ Post #4 Good Advice: Quote:
https://us-mg6.mail.yahoo.com/ya/dow...d=YahooMailNeo Note that it has only a single wire attached to it. |
