-   C4 ZR-1 Parts For Sale / Wanted (http://zr1.net/forum/forumdisplay.php?f=10)
-   -   FS-Complete Valvetrain and cams- 700hp (http://zr1.net/forum/showthread.php?t=24639)
tpepmeie 02-07-2015 10:47 AM
All,
Now that I have the new cam cores, I have decided to switch over to mechanical (solid) followers on this version of the 427. And bigger cams, in search of 800 hp. :jawdrop:
So, I am offering my entire valvetrain from build 1 for sale. It is a matched set, so I won't break it up--the components have been selected designed to work together as a system. This isn't for the faint of heart, but it will make an honest 700 crank hp, with a good set of cylinder heads.
The entire system has maybe 4 hours of dyno time and 2000 miles of spirited driving.
  • (4) custom billet camshafts (Integral Cams)
  • (16) Stainless intake valves, 39.5mm (SI Valves)
  • (16) Stainless exhaust valves, 35.5mm (SI Valves)
  • (32) Custom Titanium retainers (CHE Precision)
  • (32) Custom hardened steel spring seats (CHE)
  • (32) Valve locks / keepers (Ferrea)
  • (32) Hydraulic lightweight followers /lifters (INA)
  • (32) Valve springs (Eibach)
I will help the buyer with setup advice, if needed.
Price: now $8000
Pictures:
http://i1036.photobucket.com/albums/...e/IMG_2671.jpg
http://i1036.photobucket.com/albums/...e/IMG_2678.jpg
http://i1036.photobucket.com/albums/...IMG_2283sm.jpg
XfireZ51 02-07-2015 03:29 PM
Re: FS-Complete Valvetrain and cams- 700hp
Todd,
ActUally that is an amazing price for all the gorgeous hardware shown. I'm assuming we won't see you at BG then?
tpepmeie 02-15-2015 07:46 AM
Weekend bump?
5ABI VT 02-18-2015 09:24 AM
So pretty. How would these cams do on a stock ci LT5? :-D
XfireZ51 02-18-2015 10:45 AM
I think the word overkill would not be an adequate statement.
A26B 02-18-2015 11:18 AM
:sign10:
5ABI VT 02-18-2015 11:38 AM
Sounds right up my alley then :)
tpepmeie 02-18-2015 08:08 PM
Well, it depends how good the cylinder heads are, and how high you want to rev it.
My calculations, using the stock 93mm stroke, show you need to rev it to around 7600-8000 peak power speed to take full advantage of that duration. More stroke brings that peak power speed down.
The biggest issue you face is that you will need valve reliefs in the pistons. These cams have .150" lift at TDC intake, and .102" lift exhaust at TDC. You can work out the piston to valve clearance from that.
Todd
rkreigh 02-19-2015 04:18 PM
wow, that is some serious stuff there
probably wake up the old LSV a bit
I would think this stuff would be best for 330 cfm plus ported heads with a stroker
the lil 390 might do them justice if I took her up to 7500 or so
good luck with the solid cams, I admire your willingness to experiment
fastlane and graham should know most about making it work
800 NA will be simply amazing are you turning it up past 8k
tpepmeie 02-21-2015 04:19 PM
Ron,
700hp is doable with a net 305-310 cfm (through the plenum, TB, and airhorn). That takes at least 335-340 @ .450 lift just through the heads.
Your LPE's are probably close to that.
These are really nice cams, and I'm having second thoughts about letting them go. One-of-a-kind, for sure. I wish Steve wouldn't have closed his business (Integral Cams). His work was first rate, and his knowledge of metallurgy and spring stresses was tremendous.
As for my next version... no, not 8000. Not with a 4" stroke. 5000 fpm (7500 rpm) is the absolute limit I feel comfortable with for an endurance build. I intend to make peak power at 7300-7400 rpm.
