-   -   Aftermarket Differential Cover or drain plug mod? --- (http://zr1.net/forum/showthread.php?t=23818)
alwayscode390 09-15-2014 11:13 PM
Is there an aftermarket rear differential cover for our cars?
The stock one is just stamped steel w/o a drain plug, right?
I thought I heard someone mention a kit to tap a drain plug into the stocker ... I'll look into that if its the only option.
I'm about to swap out the fluids and would like to change it up if possible.
Thanks! ---
USAZR1 09-15-2014 11:24 PM
Re: Aftermarket Differential Cover or drain plug mod? ---
Thanks! ---
The oem cover is cast aluminum,IIRC. I've seen billet covers for our 44's but can't remember who makes them. Will try to find out.
I'm kinda surprised PML doesn't offer one.
alwayscode390 09-15-2014 11:29 PM
Yeah, PML is where I just got one for the SRT8 Jeep I have.
Its a Dana 44 in the rear? Anything make it different than any other Dana 44?
They have a low, high , and top fill version http://www.yourcovers.com/diffcover_6057.php ---
mike100 09-15-2014 11:38 PM
drop down on one knee and you'll know why it isn't just a cover.
alwayscode390 09-15-2014 11:40 PM
Yeah I really should have gotten under the car before making this thread but its dark out right now ... I may get under there tomorrow.
I found a good thread from last year on how to drill/tap the stock cover.
http://zr1.net/forum/showthread.php?...ight=dana+rear
alwayscode390 09-15-2014 11:45 PM
I've been told about the "batwing" mounts , I need to see them for myself to understand how it mounts the rear-end to the frame.
I guess that scratches the idea of the D44 covers from PML HAHAHA ---
mike100 09-15-2014 11:46 PM
http://i.ebayimg.com/00/s/OTAwWDE2MD..._id=880000500F
alwayscode390 09-15-2014 11:56 PM
Ahhh ok, I see the wings LOL :)
I didn't realize those were connected to the cover vs the actual housing though. Thanks!
I found a tap kit too , is this the only one available?
http://www.parts123.com/parts123/yb....Z5Z50000050~~~
XfireZ51 09-16-2014 12:09 AM
Had a drain plug installed w last gear change.
USAZR1 09-16-2014 12:47 AM
Dang,talk about brain fade! Can't believe I forgot about that "little" detail,Mike. :confused:
