-   -   R134 A/C conversion (http://zr1.net/forum/showthread.php?t=22815)
LantanaTX 04-27-2014 09:17 PM
R134 A/C conversion
Does anyone know where the orifice is? I realize I can just put the R134 in but changing the orifice to a variable results in colder air. Usually there is some dimpling in one of the pipes near a union which holds the orifice but I am not finding it on this car.
WVZR-1 04-27-2014 09:36 PM
Re: R134 A/C conversion
Drops in the evaporator tube.
LantanaTX 04-27-2014 09:38 PM
Great thank you!
WVZR-1 04-27-2014 09:41 PM
Originally Posted by LantanaTX (Post 201854)
Great thank you!
You should see the crimp in the tube. Those connections can be difficult to unthread.
The crimp can be seen here:
http://www.ebay.com/itm/AC-Evaporato...d0ba3b&vxp=mtr
Schrade 04-27-2014 10:11 PM
I converted an '87 to 134 without changing any hardware, except an adapter fitting, that I remember.
I did do the conversion flush a couple extra times, and vented it ( just to see how much was left, of course ;) ), and had no problems thereafter.
LantanaTX 04-27-2014 10:53 PM
I did the same the first time I converted one, but it never got quite as cold and then I learned about changing the orifice and then freezing cold.
LantanaTX 04-27-2014 10:55 PM
Thank you, I must have missed it. Just couldn't see the crimp. They are usually at the evaporator or the filter dryer.
scottfab 04-28-2014 11:32 AM
chances are you're going to introduce some moisture to the system when you put the new orifice in I would suggest changing the dryer while you're in there. they are surprisingly cheap
LantanaTX 04-28-2014 12:03 PM
Never had to replace a dryer before when doing this, but the system must be evacuated before charging.
GOLDCYLON 04-28-2014 01:31 PM
Its always recommended to change out the receiver driver before doing the conversion. Your going to have to recharge the system anyway.
