infl rest passenger side
Where is the passenger side sensor mounted? About to tackle it. Thanks
Re: infl rest passenger side
Its under the blower fan assembly on the frame rail.....should be in the same location as the driver side you have already fixed, except the passenger side of the car. :)
It's doable little tougher to get to because something is mounted to the firewall just above it. It's been a month since I tackled it so can't remember exactly. Look up and under with a flash light you will see it. |
I see the bugger. Can you leave blower motor in place?
Yes it is actually under the heater core box........no need to remove anything other than.....rocker panel, side panel and inner fender skirts. I removed all three for cleaning while I was there.
Ok I'm in reassembly now.
I'm done. Cleared code. But it comes back as 26. Now what?
It could be a bad sensor.........just a thought maybe someone else will chime in.
That was my first thought as well. Any way to test these things?
[IMG]http://i1323.photobucket.com/albums/...ps49be85a2.jpg[/IMG] |
