ROUGH RUNNING
Hi
My 1990 ZR1 has a fault which I am trying to identify. The symptoms are:- it starts from cold and runs perfect, good miles per gallon, etc., when engine has been stopped for 15 mins it starts up running rough and the miles per gallon go down significantly, at tick over the fly wheel starts rattling. When left alone for 45 mins it starts up perfect. I have tried shorting the socket for the diagnostic and no codes appeared, I am thinking it is something to do with the oxygen sensor or a temperature sensor. I would appreciate any help. |
Re: ROUGH RUNNING
Welcome onto the boards there...
Maybe not necessary to start 2 threads on the topic. Cold start doesn't tell much, and highway running doesn't either. WARMED up [Closed Loop] idle quality means more than anything IMO. Rattling is likely the dual mass flywheel. What makes you think O2's? Or Coolant Temp Sensor? Do you have FSM for the car? And a multimeter? |
Re: ROUGH RUNNING
Thanks for coming back to me.
Two postings was a mistake, I'm new here. Yes, I think it is the dual mass fly wheel rattling. I am not technical but happy to learn, what is IMO ? Is FSM service manual ? I don't have multimeter but thinking of buying one. |
Re: ROUGH RUNNING
it takes a lot for the dual mass to rattle and 02 sensors won't do it. you could have failing injectors
Re: ROUGH RUNNING
IMO = in my opinion...
FSM = Factory Shop Manual. And a fuel pressure test, with leakdown time, is in order. How many miles on the car? |
Re: ROUGH RUNNING
Just a guess, could be a bad coil when hot.
Re: ROUGH RUNNING
Find a TECH 1 scanner so you can look at all the ECM inputs - this does sound like a failing coolant sensor, but better to be sure rather than throwing parts at it.
Re: ROUGH RUNNING
Re: ROUGH RUNNING
Re: ROUGH RUNNING
