Fs: c6zr1 Brembo calipers set
Hello all, I am selling a set of the C6 Zr1 Brembo calipers. These are for the front and rear. These are OEM not after market and the colors is gray. I don't have pads or rotors. They are new never been driven just mount for mock up on a car. One of the caliper have scrape during mocking up (refer to picture below). It does not effect performance. These are the ultimate calipers. The fronts are 6 pistons and rear are 4 pistons. If you ever seen these calipers they are really massive and the stopping power is unbelievable. I am looking to get $1500.00 or best offer.
http://forums.corvetteforum.com/c6-p...ipers-set.html Shayne, |
Re: Fs: c6zr1 Brembo calipers set
Shayne,
How do these bolt up to the hub carriers? |
Hi, in order to use these calipers you have to use a c6 zo6 adapters. The wheels must be 19" or bigger but not all 19" wheels will fit so you must check with your wheel manufacture.
Shayne |
Shayne,
I was primarily looking at the rears. IOW, do you need the C6Z adapter for the rear Brembos or are they bolt ons, unlike the stock C6Z rear calipers? Do these require the "hub/drum" eBrake assembly like the stock C6Z? They look very similar to the CTS-V and ZL-1 Brembos. |
The rear is a little more complex. Requires all c5 and c6 rear drum assembly. You can get the adapters from street custom. They machines a beautiful one piece set up really really nice. Then everything bolts right up. Yes Jeff you are correct.
Yeah I do and I am guessing my front Brembos are the size of these rears..
Yeah those are cool looking brakes though |
