-   -   Weatherstripping (http://zr1.net/forum/showthread.php?t=20245)
XfireZ51 05-16-2013 12:48 PM
Weatherstripping
Thoughts on which vendors are the source of better quality weatherstripping?
Who's had experience w any of them?. I need to replace my A pillar gaskets along w door and probably window sash.
GOLDCYLON 05-16-2013 01:10 PM
Re: Weatherstripping
Wilcox :cheers:
Been there done that
-=Jeff=- 05-17-2013 10:41 AM
Keen Auto parts.. they have the Latex stuff almost as soft as OEM for the A Pillar..
I have a piece from Melrose too, you can try the melrose piece if you want
-=Jeff=- 05-17-2013 10:44 AM
The part number for the Rear B Pillar and Roof Weatherstrip Latex Weatherstrip is 460284.
The part number for the Front A Pillar and Roof Weatherstrip Latex Weatherstrip is 460285.
They sell for $170 each.
I don’t believe they are listed on the website, so you can call me direct (800-757-5336) if you want to order them.
Let me know if you have any other questions.
Thanks!
Kevin Sphar
Keen Parts
Kevin@KeenParts.com
800-757-5336
www.KeenParts.com
scottfab 05-17-2013 10:46 AM
What is the advantage of Latex here?
GOLDCYLON 05-17-2013 11:21 AM
Well I know Latex does not hold up to heat. So im not sure how they would do in Arizona vs traditional rubber. I only can relate to what Ive been using over the years.
-=Jeff=- 05-17-2013 11:37 AM
Softer like OEM stuff.. the Melrose stuff is close to OEM, but i have found that the Latex seems to be he best for me so far, it feels just like OEM and I finally have the windows adjusted so there should not be any leaks
pantera1683 05-17-2013 02:30 PM
Which company sells the best weatherstrip for the hatch? The one I bought from Wilcox split on both sides within a month :mad:
scottfab 05-17-2013 05:12 PM
Did you take pics?
G8nightman 05-20-2013 03:40 PM
Just odered a complete set from Wilcox. Hope they are good.
