LPE 475: Should I Eliminate Secondary Stuff If Changing Injectors?????
Hi, I have a 90 LPE 475 Package ZR-1 I bought in January 2010. I was using it for a Daily Driver in 2010 & 2011. It started developing what feels like a miss when the secondaries kicked in. If I would turn the Valet switch off, the noise would go away. I scoured this board & pretty much decided to change both sets of injectors, as I think they are still original. Now, a couple of Questions:
1) What are the "best" injectors to use? I don't care about a couple of hundred $$$ difference. 2) Would I be wise to delete all the secondary stuff since I'll be in there? 3) Anything else I should be doing while I'm there? This is a really cool car. It was John Benders car when he did "One Lap of America" (Came In 5th). When I bought it, the seller really did not know a lot about it. It had all "Bottom of the Page" stuff from Doug Rippie in it. This is a car I will imagine I'll keep forever & I don't have to comply to Emissions Testing. Thanks in advance. |
Re: LPE 475: Should I Eliminate Secondary Stuff If Changing Injectors?????
I'm not the expert, but I'll chime in first.
The 1990 injectors will not tolerate the ethanol in fuel these days, that being said, do not buy GM injectors. Popular choice seems to be Fuel Injector Connection. Popular seems to be the SS, new. As opposed to rebuilt. I have not done mine yet, maybe this winter. F.I.C. is where I'll shop. Secondaries. Some members have had some major engine issuses when the secondaries fall apart and you injest parts. This don't sound good to me. Rumor has it, if you remove them, you'll loose a couple mpg. Steve |
seconday's removed and accel injectors here, all good, chip will need reburn without secondarys
Pull em I posted up my argument for doing so. GC
Re: Eliminated Systems
Don't you have the same links to your solutions on our forums? I'm confused |
Do you have emmisions in your state?
Pete |
Re: Emissions Testing in PA
Then Jerry's gaskets. www.jerrysgaskets.com Might want to consider doing coil packs and spark plug wires while you are there I removed my secondaries and no issues. Need to retune and reprogram he chip. :cheers: David |
