-   -   ABS code 76 set (http://zr1.net/forum/showthread.php?t=17725)
Don in VT 06-17-2012 08:55 PM
ABS code 76 set
How do I clear ABS codes without Tech 1 ?
Thanks
Don
tccrab 06-18-2012 05:21 PM
Re: ABS code 76 set
To the best of my knowledge, ABS codes have to have a TECH1 to reset them.
'Crabs
tccrab 06-18-2012 09:39 PM
Re: ABS code 76 set
Found this tidbit on a Canadian StripClub bathroom wall:
code 76 is lateral accelerometer. He needs to remove it and whack it in his hand to make sure the pendulum on the inside is loose. Otherwise it needs to be replaced.
You can clear the codes on the ALDL connecter. Page 5E1-3 gives you the proper sequence for grounding.
The only codes you can not clear with the ALDL are 41,45,55,61,63.
'Crabs
scottfab 06-20-2012 08:36 AM
Re: ABS code 76 set
Originally Posted by Dynomite (Post 143698)
The EBCM will not permit code clearing until all of the codes have been displayed. .
Don, this part I'm not sure of but if the grounding/ungrounding of pin H that I sent in email fails then do wait to see all codes first.
Hib Halverson 06-23-2012 11:59 PM
Re: ABS code 76 set
'Crabs
You can't "replace" the lat sensor because there are none available. If your lat sensor is bad, the best you can hope for is to find a good used one. Fortunately, ZR1 lat sensors are the same as base C4 lat sensors. When looking for a used unit, get one from a 90-93 model year ZR-1. The 94-96 sensor is different.
72ZR1 06-24-2012 11:03 AM
Re: ABS code 76 set
I had to take the sensor apart and center the pendulum by hand using a ohm meter.the sensor doesn't work but the abs light goes out.i don"t track race so that"s ok.
Hib Halverson 06-24-2012 12:40 PM
Re: ABS code 76 set
It's very important to note that the need for the lateral acceleration sensor is not strictly driven by "track racing".
The ABS senors information is used by the ABS controller to enhance rear brake performance when braking and cornering at the same time.
This would be of critical importance during street driving in wet weather or in dry weather in a emergency evasive situation.
If the lat sensor is not working but ABS is working, you have a potentially dangerous situation regardless of whether or not you "track race".
Also, if the lat sensor is not work but ABS is working you may experience the ABS enabled on the rear brakes when driving in a straight line and there is no impending lock-up, ie: a "false" ABS application.
Bottom line, from a safety standpoint you are better, letting the sensor be out of range so the code sets and ABS is disabled. Just ignore the ABS Service light while you're looking for a used unit.
John Boothby 06-24-2012 01:03 PM
Re: ABS code 76 set
What year is your car, Don? I have a used (working) lateral accelerater sensor (large kind). I believe it came out of a 92 or 93, but it is not the '90 (small one), I do know that. It lives behind the radio. You can have it if it is what you need. Just pay shipping. IT DOES NOT FIT A '90.
If you are interested, I will pull it out of my spare parts box and check the pn# for you.
scottfab 06-25-2012 09:15 AM
Re: ABS code 76 set
Don how do you know the sensor does not work?
I did this same thing with mine years back and it's never stuck again.
I have a theory on how they stick but it's beyond the scope of this tread.
72ZR1 06-27-2012 02:57 PM
Re: ABS code 76 set
if the pendulum is sticking the computer doesn't now if your going around a corner or in a slide.it it thinks your always going straight.
